41 - 60 of 65 Posts
Glad my parts got there safe Troy, googled your address and 3 different places came up nearby.
Discussion Starter #42
rear subframe,throttlebodies and rearlamp arrived!
almost there, you guys have been awesome!
heres what we still need:
right fairing + under headlamp fairing +air tubes
some sensors:
boost sensor,air temperature sensor,speed,water temp etc.
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #43
forks,front master,front spindle and brakelines arrived:cheers
some sensors:
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #44
forks,front master,front,some bolts&fittings,spindle and brakelines arrived:cheers
some sensors:
boost sensor,air temperature sensor etc.
lock set
fuel pump
throttle tube
front mudguard
some sensors:
lock set
fuel pump
throttle tube
front mudguard
About time lol, i couldnt track it past denmark for some reason.... but glad its there :thumbup - cant wait to see the beast :)
Discussion Starter #46
first pic:
some sensors&relays:
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #47
Tank and clutch assy arived! :)
first pic:
lock set
fuel pump
throttle tube
front mudguard
Is it going to be a supprise or does the guy know ?
Discussion Starter #49
he didnt know when i started this but he knows now!
Discussion Starter #50
ECU arrived!:thumbup
first pic:
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #51
Sams box arrived
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #52
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #53
thermostat housing,speedo sensor and some small bits arrived!
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #54
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #55
:banghead dont know how i thought that i have clocks!:banghead
CLOCKS!
lock set
fuel pump
throttle tube
front mudguard
Discussion Starter #56
CLOCKS!
lock set
fuel pump
throttle tube
some pics:
Discussion Starter #57
CLOCKS!
lock set
fuel pump
throttle tube
Discussion Starter #58
i have started to take my bike to bits,so we can start the build,but been really busy at work so itll take some time until i can start the build!
CLOCKS!
lock set
fuel pump
throttle tube
rear pegs
Discussion Starter #59
HELLO! THE BUILD STARTS NEXT WEDNESDAY!
CLOCKS!
lock set
fuel pump
throttle tube
rear pegs
Discussion Starter #60
CLOCKS!
lock set
fuel pump
throttle tube
rear pegs
41 - 60 of 65 Posts
