1 - 12 of 12 Posts
plug the inlet to the pump where the sock attaches and soak it in CLR
if the pump still runs it will be fine.
and the outlet too of course
Your TL must run on saline :lol
Ring-in; when you said "soak it in CLR" did you actually mean "soak it in cola"? :laugh
Surprisingly the crap brushed off easily in about 4 mins .
The pump was blocked so I removed the end and blew some air through it then some wd40 .
To my surprise it started working
In side the tank looked just as bad , so I threw in a handful of bolts and small amount of rust kill .
After shaking the tank for 5 mins I removed the bolts with a "magnet on a stick " and flushed . A LOT better .
Then plugged up the gas opening ,added 500m of Hydrocloric Acid (pool supplies ,very cheap ), plugged the pump opening (rag) and swilled it around for 1 min . Drain and flush . Don't breath the fumes its powerful. Be warned .
Result ,one 'AS new " , tank .
The bike had sat for 3 year and smelt terrible . The fuel looked like varnish with handfuls of scale in it .
I'd say you win a clean gas tank! Good work.
I hope you took lots of images of the procedure. I would like to remove mine eventually, and swap out the fuel filter.
Hydrochloric Acid :confused I always used Vinegar
Vinegar is for sissies. Anything that doesn't actually burn holes in things doesn't count as proper acid. :rotfl
1 - 12 of 12 Posts
