Tried doing a search and didn't come up with anything current or that I've already tried...
The bike is a 2000 TL1000R
I took it out for a ride after it was a little fussy about starting. It felt like it was running on one cylinder and after a couple of minutes the second one kicked in. It ran fine for about 40 miles and I stopped and took a break.
When I fired it back up to head home it only ran on one cylinder all the way.
Once back home, I took apart the airbox and dropped the radiators. I looked at the linkage (everything was fine), checked compression (good), and checked the spark plugs for fire (good).
When I pulled the plugs, the front one looked like a plug from a normally running cylinder. The rear one was clean but dry looking. This leads me to believe I'm not getting fuel to the rear cylinder.
Is there anything I'm missing before I pull out the injectors and try cleaning them?
