Hi all,
Saw this morning that on the bottom end of my steering danmer the shaft if full of oil and it seems to be leeking from the bottom of the damber onto the shaft.
I guess the seals are done fore, Can I replace them on the OEM damper or will I need to Replace with a new one, or just chuck it of and hang on!
Thanks!!
:yes If it's leaking, you'll need another.
You can't get the seals from Suzuki as the damper is a non serviceable item.
But if you get them out (undo the ends), a bearing supplier will be able to mesure them and might be able to source some.
Scooter hottie chauffeur
is the R and the S damper the same?... might have one in my gigantic stack of stuff
