1 - 3 of 3 Posts
I've just refitted the throttle bodies on my TL1000S, 1999 UK model, and I have one vacuum connection on the rear throttle body which I don't know what it connects to. It's just above a capped off vacuum connection at the base of the throttle body (see pic). UK bike so I believe it should never have had a PAIR system on it.
On the parts fiche it shows a pipe connected to it, pointing downwards, which appears to be missing on my bike but it doesn't show what the other end is connected to.
Does anyone know what this should be connected to? The only connection that looks likely is on the pipework to the air box vacuum valve - see 2nd pic.
I should add that I haven't had the bike running since I bought it, as it was bought as a project, but I did hear it running when I looked at it, so can only assume that the bike was like this before.
65005
65006
look at this post...............
and you can download the manual from here ...............................
That looks like the diagram that I needed showing how everything connects to everything else. Should be able to work it out from that.
Thanks mate.(y)
1 - 3 of 3 Posts
