1 - 13 of 13 Posts
Its time to put the coils back on the bike trouble is which one goes where.
which side of the frame does the rear coil fit on ( long lead) and which side does the front coil fit.
Can you tell from the part numbers stu?
15 COIL ASSY, IGNITION
33410-48E00 1 $63.01
16 COIL ASSY, IGNITION
33420-38A11 1 $64.82
looks like the rear goes on the left
thanks mate.
Or the front on the right.
(The harness and wiring diagram would probably have confirmed that too)
The only manual I have at the moment is for the R :banghead
Longest coil is for the rear and goes on the left with the terminals pointing forward
Shortest on the right terminals pointing back
On both sides the bump for the lead points down
On the rear cylinder the lead passes next to the cam idler bolt which means removing the left engine mount spacer again to get it in :devious
Could you be a bit more specific Sam?:rotfl
Its still early in the day over your way sam .
wanna stop by for a cuppa and lay out the harness with me :lol
10am and I'm sat in bed on the laptop :laugh
I'll just grab my clothes and I'll be there, bloody freezing here so I'll come share some of your sun :laugh
Discussion Starter #12
8.15pm here
present temp in the city 27 C and maybe a light drop of rain.
where else can you walk around in a pair of boxers with a light mist of rain and still be comfortable, :banana
I'll put he kettle on then, :laugh
I hope it's solar powered or it might boil before I get there......just starting to snow here now :banghead
1 - 13 of 13 Posts
