Venhill cable's! Good but not cheap!
Venhill cable's! Good but not cheap!Any recommendations for where to get extended clutch and throttle cables made up, putting renthals on as getting old and back knackered.
I know, I know, but it's that or give up riding my TL1000S, and that ain't happening.
Uk.
Actually the hardest one to make fit was the fast idle cable.Clutch cable from a Yamaha SR 125 is a bit longer.
When I did mine I routed the throttle cables to the other side of the headstock. The stock cables will fit this way. Brake lines may need replacing with slightly longer ones.
