I was looking at Ron Ayers fiche page trying to figure out which clutch push rod seal I need for a 98 TLR... There are two part #'s listed... One is for a 5.5mm seal, and the other is for a 5mm seal... Does anyone which one I should get?
I'm also looking for the part# for the counter shaft seal if anyone knows that too.. I'm having trouble finding it in the fiche list...
http://www.ronayers.com/fiche/frames.cfm?man=su&groupid=12250&parent=12210
If it's the same part number as for the S then 5.5 is good.
The clutch rod seal was an issue for my 99 TLR. I put an SV1000 seal in and it fit perfectly and haven’t had an issue with leaks since. It’s more substantial. I also did not enlarge the retaining plate and I didn’t have any issue.
