1 - 2 of 2 Posts
Well I starting noticing it last week. First started when I noticed the clutch slipping in 3rd and up gears when I jump on the throttle. Then today I started to hear some noise when starting out in first. Also, I think I can hear it if I come off the throttle. I kinda sounds like something is loose.:O I did some searching around the zone and can only come up with maybe the clutch springs may need replacing?? But would that also cause noise along with the clutch slipping??? I also thought that something may be outta line but I have not had the clutch apart??? Would the worm drive being out of adustment cause this???:confused
Any help would be great!!!
remove the clutch cover.... it may be the bolt holding the clutch spings in coming lose......it happens
1 - 2 of 2 Posts
