1 - 3 of 3 Posts
i put a new clutch cable on my bike this morning as the leaver has been very heavy to pull and i thought the cable might be coming apart,this turned out to be wrong:banghead the worm drive is rather worn but still working,BUT i still cant get any gears when the bike is in neutral:banghead
any ideas:O i was thinking clutch....................but when its running (i started it in gear) there is no slip at all:coocoo the "bite" point is at the end of the leaver but it always has been so could it be the gearbox,iv heard there not the most sturdy unit on the market:laugh
any help would be nice:) Thanks Dave
sounds like the clutch isnt disengaging..with the motor off but in gear can u pull the clutch and push the bike ..it will be a bit stiff ( to push the bike ) but should allow you to tell if its disengaging.
1 - 3 of 3 Posts
