Last night on the way from work, I pulled the clutch in at a light to put it into gear an I heard and felt a "click". Got home and looked at the lever and saw like 2-3 strands complete cut through. The little cylinder that the cable is connected to at the end that goes into the lever itself was splitting and 3 strainds had been cut through.:O :O Go figure!?
Oh well, I'm going to replace the cable and maybe even the worm drive (since I never have) Do you have any suggestions as to what I should look out for? Is pulling and re-installing the cable a pain in the butt. Oh yeah, I had a question about my adjuster. It is almost impossible to turn in or out without having to use a freakin pair of plyers. same goes for the brake adjuster. What's up with that.:confused :confused
