I am about to replace the Clutch Lever and the Brake lever with new ones, I'm just wondering if there are any special words of wisdom I need to know before i enbark upon this task. I am also going to change out the foot/shift lever also. how much of a problem is that going to be? thanks guys!
Gee
yeah, thats the same one I got, but I got the silver one. :) I like those luckybike guys., I couldnt believe how fast they got me my stuff..!!
Gee
Don't forget the micro switches under each lever perch.
The retaining bolt (10 mm hex) holding the pedal pivots is loctited from the factory so you might need a power bar.
Don't forget to clean and lubricate the shift pedal pivot and check for smooth movement before refitting the selector shaft arm :O
