hi guys,
how much should a chimney sweep cost?
i think im due...
i think im due...
veetwo tls said:get one of these you'll never look back
http://www.google.com.au/search?hl=en&q=split+system+air+con&meta=&btnG=Google+Search
maybe ill do that. looks like $150 or so to get a local guy and i have the simplist chimney ever... not even an access door... and its only 12 or so feet high...BikePilot said:N2, you can buy a sweep brush and handle (it comes in ~4' sections that screw together, easy to use) for ~$35 at lowes. It takes less than a half hour to do a good job. I use a wood stove for supplemental heat in the winter and sweep my own chimney:thumbup
I seal off the fireplace from the inside of the house (easy to do with a wood stove installed), open up the outside clean out door and then go up on the roof and run the sweeper up and down it - back down to the clean out door with the shop-vac and I'm done:cool
:stupidone thing to think about is that the person you hire should also do an inspection of the internal condition of the chimney. This can be an issue if it's an older houise. It doesn't take any more than a crack in a motar joint to allow enough heat out of the chimney to start a nice smolering fire inside the wall.
