While making a shift from 1st-> 2nd (or could have been 2nd->3rd?) and accelerating hard it seemed to pop out of gear. My second up shift attempt also resulted in nothing. Third attempt worked and never had a problem the rest of the day.
Is it possible for a bike tranny to pop out of gear? Or just an excuse for missing 2 and hitting N, then sticking in N? :coocoo
Bent or worn shifter forks, rounded off dogs can cause a gearbox to jump out of gear. Worn dogs can make it happen on acceleration too.
you might have been lucky and just screwed up the shifts or even the lever pivot if gummed up it wont shift properly - But if starts doing it regularly, check return spring first then your better off dropping the engine before real damage occurs.
Thanks for the info. I will actually be pulling the motor this winter for frame powdercoat. Maybe time for inspection just in case. Bike has 24-25k miles and flawless other than that 1 incident.
Talk about a pucker factor too...loosing all power in the middle of a pass is not a comfy feeling when you're on top of a corner in the opposing lane. :coocoo
GP Star or someone makes a fancy spring/shift star that is supposed to improve things as well. Also do take your shifter off and clean and lube the pivot. Its a rather sorry design and gets gummed up and sticky in short order. Somewhat frequent cleaning and lubing makes a huge difference in shift quality. Also make sure your clutch is well bled.
good luck
Kian...Kevin Cini over at Higgins put the Factory Pro shift kit in his TLS, shoot him a pm and see if it made a difference :O
