nope you will need a power commander or a yosh box or similar to do that
have you got a tre fitted? it could be messing with the idle if its not a smart tre
Since you have a functional power commander with a laptop, you can put the A/F mixture wherever you want it by simply editing the map values that impact the idle.smart tre and pc111 fittedJust hooked up the pc11 to the laptop to check the map and it was blank ??? so i've sent a map to it, runs better but not perfect. Interestingly, when its idling and I pull the clutch in the idle rises to around 1500 and smooths out...... Seems strange
Rich
