Please I traded my mustang and got this bike and it's a project bike and we'll the fi light is on and since the key got lost I'm told this would be the easier way to be sure it will start before going through what it will cost to get key made I've already got the 100 ohm resistor just don't know what all wires I need to use
I'd much appreciate it
I'd find how much a locksmith would charge you to make a couple of new keys. It might be worth it to source a new/used ignition switch, gas cap, and truck latch. If you go that route, I'd highlu envourage you to purchase OEM, not aftermarket. I don't know what the resistor would be used for, but then again I am in no way an electrical person. With that said, I don't know as I would recommend installing anything onto the stock harness before first making sure everything is operating as it should be.
Get a copy of the service manual, go through the fault finding. I do not understand how you have the FI light on without the key. More info and photos might help.
