1 - 2 of 2 Posts
Hello, my name is Ilya and I live in Russia, I have a Cagiva navigator, I do an off-road custom. The motorcycle of 2003 was taken as the basis. I put the fork from the ktm 950 adventure, replaced the cartridge with my own production, the fork stroke is 265 mm, you can make 290 mm =). My friends made protective arches, the luggage system was already on the motorcycle with givi wardrobe trunks. I had a fall, and I broke through the crankcase, I’m probably crazy, but I cut it and brewed it, it increased the ground clearance of 20-30 mm. The motor is standard, the rods were replaced, because they are lighter, the engine would not start. Now I’m doing installing a shock absorber from ktm sxf 450 will be a compact and protected progression. There is also an injector and a control unit and wiring from suzuki tl1000r, I think to install. j1qGehWLZpM.jpg
1 - 2 of 2 Posts
