1 - 2 of 2 Posts
Took her for a ride today 97 tl1000s was going lovely till red lined it in 2 gear engine cut out straight away pulled over fl comes up got switch for dealer mode c11 comes up camshaft sensor. bike turns over fuel primes up just not firing how do I test sensor to see if it's the sensor or something else???? And where's the best place to get one. Haven't checked the wires or connectors yet just got recovered. Haha any advice cheers
There have been a couple instances in the past when the pin in the camshaft came out. This pin is what triggers the sensor. Seeing as how yours failed at high RPM, you may want to check that first.
Just remove the rear valve cover, and it will be plain to see.
1 - 2 of 2 Posts
