Or bedding them in, whatever you call it ... how to do?
I finally put SK's semi-floaters on and new Galfer pads into fresh tickled up calipers on the TL and with the battery charging (maybe) I should be able to ride this week :doug :doug :doug
What's the procedure to make sure I don't glaze the pads and rotors and mangle the whole lot up? Thanks in advance I go to bed now
I've seen different things suggested. I think the only really universal recommendation is to avoid braking for really extended periods of time as you don't want them to get too hot before they are bedded in.
I usually braking lightly for a short distance a few times, then brake harder a few times, then ride like normal.
When I got my new rotors I followed the bedding in instructios to the letter. As Bikepilot said, take it easy for the first few hundred k's and avoid any hard or prolonged braking. I did all this and the buggers still glazed after 1000+ k's. Rubbed the discs and pads with a bit of smooth wet n dry and they've been good for nearly a year
It really depends on the pads.
For track, I stopped buying pads that you must break-in, it's a major pain in the ass. The carbon pads I use just need heat and they work.
One very simple trick when you change pads/rotors is to roughten up the rotors radially (from outside towards center or vice versa) using a scotch pad. Don't use sandpaper, just a rough scotch pad. Like that the pads bed in a bit faster.
