Hi guys,
I have a 2000 TLS 1000 with rear BITUBO rear shock absorber.
However, I couldn't find anywhere the documentation to set it to it's default setting (and maybe the "sport" setting too?).
I wouldn't like to screw up and make the current setting worse (even though it s*cks lol).
If anyone could help, i'd be real grateful.
Thanks in advance for any docs and advice :)
P.S: Additionnaly, I heard that front shock absorber configuration (like amount of fork oil) vary according to years, is it true? If so, could you tell/show me the default parameters for 2000 year?
Hi sorry for late reply, I have a TLs with the same shock. Do you still need some info?
Hello yes if possible i would like to know how to adjust the setting on the BITUBO rear damper. Maybe if you could give me the "default" settings and sport settings. And if you have the official documentation it would be even better.
Thanks in advance.
I don't have standard settings but I can recommend Dave Moss !
You will learn to set sag for both front and back, and a whole lot more.
