Yes, use the search feature. Common to bore & replate & use J&E pistons. The Kendall Berg kit is even more promising: bored to the water jacket then sleeved with cast iron, Arias pistons and I can't remember whose rods. You can also get the crank stroked either way. Either way (sleeved or not) is expensive. The gain is reputed to be more than you'd expect because the bigger bore unshrouds the valves, moving the cylinder wall farther away from the valves so the valves flow better.
Had the +2mm bores on my SV with cams and adjustable gears. All Spears Enterprises Parts. Ran like a champ. :)
spears cams are good
that must have been a fun ride :)
is it gone?
:thumbup someones lucky to have it
