my 97 tl1000s backfires when cold or when i ream on the throttle and let off... when i let off it backfires. is this normal or do i need to adjust some valve? it only has 25k miles.... i live in seattle
Yup, i had the same issue. Those pops can go a long way to making shit of a CF can too!Often, the doughnut gasket between the stub pipe and header on the rear cylinder is the culprit. When the engine is cold you may be able to feel exhaust gases escaping through that junction.
That same gasket is used not only on TLs, but also on SVs and DLs. Therefore, it is surprising that none of the shops in my area keep them on hand. They are always "special order" items. :coocoo Anyway, that's likely the part you need.![]()
they also made the police around london very twitchy when i was riding my backfiring tl down there to the world superbikes at brands hatchYup, i had the same issue. Those pops can go a long way to making shit of a CF can too!
but make sure you do it with the engine cold, and br quick cos that rear pipe gets bloody hot,very quickly+1
Start the bike up and put your hand near the joins and see if you can feel any gases escaping is the easiest way.
Good Luck!
