:O I've got a modified airbox,and a PC11 with Roo racing cans.I currently run the 002 map on the Powercommander with iridium plugs and the settings are as loaded with the map.The throttle bodies have been synced and balanced,but it backfires on the over-run.Any settings you guy's have used to eradicate this problem?Any info to solve this problem would be greatly appreciated:hail :hail
i removed my pair valve and i haven't had any backfires!:)
PAIR or leaking spigot gasket where the exhaust system meets the rear engine pipe.
Cheers guys I'll check them out.
My TLS shot flames hwnever engine-braking until I leaned out the small-throttle part of the map. Then again a friend's TLS threw flame while engine-braking 'cause he was too lean. Mine were a rich couple of bright sooty booms, his were more of a constant rasping popping with shorter flames.
