1 - 3 of 3 Posts
I'm going to look at a used bike and need to know if anyone can point me in the direction of what to look for. The bike in question is a 03 600RR. I know the obvious, crash damage, leaking fluids and visible abuse etc... but what else would you guys suggest? If it were a TL, I'd have an idea but it isn't and I don't. Thanks for any help!
Scooter hottie chauffeur
well there is common stuff to all bikes
brake pad / rotor wear... if he hasn't taken care of the brakes, he hasn't taken care of anything else.
Chain maint. if he doesn't keep the chain clean and greased... most likely he doesn't take care of much else.
if it's low miles and has the original oil filter... same as above.
you can look at the oil drain plug. If the bike has 20000 miles on it and the oil drain plug doesn't have a single "wrench mark" on it... either not many oil changes have been done, or the proper tool was used each and every time the 7 oil changes were done.
I get into the CSI mode. Where do I put scratches when I'm working on my bike... does this guy have the same scratches, or worn bolts, or replaced bolts...
I'm sure there is 600RR specific stuff but I don't know any.
I could go look at it with you........:coocoo
So you parting the TLR yet?
1 - 3 of 3 Posts
