Another one for the 10 step program.......
It's an illness. I just can't stop. All the phases I'd promised to work through are blending to one big feckin programme of refurbishment. I need help to release me from the menace of these wretched bikes. :eekAnother one for the 10 step program.......
The pegs and levers are by a German company called MFW. I got them from M&P in the UK.nice setup! where did you get the brake & gear lever?
Can the TLS levers fit a TLR? If it can I want to buy a set, these lever are sweet looking!The pegs and levers are by a German company called MFW. I got them from M&P in the UK.
http://www.mandp.co.uk/productsList.aspx?style=0&kw=MFW
I'm afraid I don't know. It may be worth asking MFW direct .... They have an English aspect to their website.Can the TLS levers fit a TLR? If it can I want to buy a set, these lever are sweet looking!
Well, i think the brake does, but TLS has a cable clutch and TLR hydralic..Can the TLS levers fit a TLR? If it can I want to buy a set, these lever are sweet looking!
No it's the gear lever and brake foot pedal that he's after.Well, i think the brake does, but TLS has a cable clutch and TLR hydralic..
well im looking to see if the rearset levers (gear & Brake) can be interchanged with a S to a R? it should matter if its cable or HydroDon't know if this adds any answers but the shift arm for the lever fits the clutch in the same location. I have an S with an R motor and the shift mechanism from my stock S lines up perfectly to the R clutch location. Like Jonstorp said the R has a hydro clutch but the locations are the same (I have a cable S clutch on an R motor). So as long as the frame mounting point is the same ( ??? ) the shifter would line up. Probably doesn't help at all. :laugh
