1 - 10 of 10 Posts
Sam I will have some R1 forks here soon so I'll send you some details if you want.
Yes please Stu, I have made a few chanegs to the chart but not changed the master yet.
Sam, on these forks I'm getting from billy, is it running 320mm discs or 310mm? Can you remember?
I don't know Chris I'm affraid
Sam,these are my observations of 04-06 R1 forks.
When Stu and I pull them apart we might be able to fill in a few gaps
Triple Clamp Fork Centres 210
Triple clamp Top Fork Dia 50
Triple Clamp Bottom Fork Diam 54
Triple Clamp Offset 30
Fork Spacing At Wheel Spindle Clamps 160
Outside To Outside Of Wheel Bearings 124
Brake Disc Diameter 320
Brake Disc Offset 0
Rotor Thickness 4.5
Rotor Centres On Stock Wheel 127.5
Bolt PCD 150
Wheel Hub Disc Mounting Faces Apart 123
Fork Length from CL Spindle to top of Fork 729
Spring Rate ? Possibly 9.5
Spring Diam 38
Slider Diam 43
Oil Height
Cartridge size mm 20
Manufacturer Kayaba
Master Cyl Diam 16mm
Caliper Mounting Centres 108
Axle diam 22
Axle pinch diam 28
Just noticed your email,sent a copy there too
Curious if anyone has ever measured ducati multistrada forks or buell ulysses forks... got a wacky idea for a taller urbanfighter TLS project. Might be picking up a tl this weekend and would love to eventually ad a couple inches of wheeltravel to soak up the city potholes and heaves...
Chart updated, thanks Steve :)
Updated :thumbup
1 - 10 of 10 Posts
