Okay since i am stuck on a budget at the moment I need to chunk the stock damper and SOAS for my TL, I know there are multiple kits available to do the swap I have my eye on the Bitubo kit but I do not have $600 to toss at it right now. I have used Fox shocks for years and they can be had for a fair price. Do any of members who have switched to the Bitubo units on the Tillis have the eye to eye measurement of the shock it self?
Jim
I think if you're patient, you'll eventually get a deal on a used unit here on on EBAY. I oringinally had a Bitubo unit, sold it here and grabbed a used Penske from someone else here as well.
I'd sit back and simply wait rather than buy another shock you might not want in the end.
Ken
Thank you for the replys, Fox shocks are damn good comparable to the Penske Units, Pre load, and twin clicker, IE dampening and compression, and for about $150 can be totally rebuilt by the factory.
Thank you for the measurment, I am trying to be patient but I do not like the notorious crack that is plagueing the rear mount. Mine is not the top mount problem. The crack I have is the lower mount which I think carries more of the load.
Jim
Different story, I did not realize you had a frame issue to contend with.
Unfortunately I am not able to provide a riders impression about the Penske. Lost parts prevented me from riding my TLR at Beaverun in September and my season is over.
I did like the Bitubo, only complaint was that it was a bit of work for the suspension tuner to get it set correctly for my weight. I weigh 185 without gear, but the lack of adjustment range is one apparent difference between it and the triple clicker Penske I just installed.
The Penske will offer me more adjustment range and probably better feedback on the track. I will have to wait until Spring to say for sure.
The Bitubo IS a good alternative to the OEM unit for both weight savings and basic function. I did enjoy having it installed in my bike for sure. I just found a used Penske for the right price that came with the Lindemann link as part of the package.
Ken
Just curious where you will be able to get a cheep fox shock? Even their little MTB shocks retail for as much as a bitubo:banghead
good luck
I second the bitubo. I was quite happy with mine. Mine got me through a good number of trackdays nice and smoothly.
good luck
I just bought one off of Ebay for $175.00 to my door, I will have to modify the lower bracket but it should work fine. I have the winter to get it on we'll see.
