A new sound? You do understand the Tl stands for 'Ticks Loudly' yeah ?
Cheers
Tom R
If it is coming from the cylinder heads it might be the camshaft scissor gears. (The springs can weaken I guess) unless they have been removed, then it can clatter based on the tooth profile.
Neither of my TL's made ticking noises.
that ticking sound could be from many things, did you try to locate it? which part of the engine its comming from? heads, crank shaft...
i use ol school long screw driver method to locate where its making loud sound
Some TL's do tick a lot without undue issues..................go through some YouTube videos of TL's and compare your ticking to their's..........
