I am breaking my '98 TL 1000 R. It hasn't been ridden in a few years. Clean title located in Rochester Ny. See picture above and below. Prices to follow.
airbox assembly $50.00
brake and clutch levers $30.00
clutch master cylinder $50.00
ecu $200.00
exhaust $400.00
forks $150.00
Frame with clean nys title $400.00
front brake calipers (set) $75.00
front wheel $100.00
gel seat $150.00
handlebars $75.00
headlight $150.00
handlebar controls $20.00
main wire harness $150.00
motor $400.00
radiator $80.00
rear caliper $45.00
rear master cylinder $20.00
rear subframe $100.00
rear wheel $100.00
seat latch, tank cap and ignition ignition with key $120.00
speedometer $100.00
steering damper $65.00
tail light $20.00
throttle bodies $85.00
under tail $100.00
zero gravity windscreen $50.00
