Has anyone out there ever change the 1st gear sprocket? I have change the chain and clutch and still having trouble with my 1st gear, now I believe it's the 1st gear sprocket inside the transmission, I will be tearing the motor down over the winter to make sure. So if anyone out there ever done this, could you let me know how much trouble this is to performed. Thanks
I did the 2nd gear in my GSXR and found out the hard way to replace both the drive and driven gear s it was still noisy after only replacing the one that was damaged. It's not a bad idea to do all the gearbox roller bearings while you have the chance I get suitable replacements from the local bearing shop, much cheaper.
