21 - 34 of 34 Posts
Don't do it while they're on the engine :no
chew chew barley mcgrew... cuthbert dibble and crunch!!!
Not in situ Chris!
You don't need new gakets do ya if you lift the TB's carefully? Oh unless the restrictors are cut out of the gasket?? Still you could use Hylomar type stuff... orange is petrol/heat res. I think?
I have some hole cutters that may be better than dremelite!
Smooth is what ya need!!!
and anyway i thought your mother had told you that you were not alowed to go into the garage alone with the vacume cleaner anymore?........ :laugh
first things first.... lift the tank and the airbox... if you wind the throttle wide open you might be able to see (with the aid of a torch) far enough down the openings past the butterflys to see if they are restricted.... if you look at the pic steve put up you can see there is quite a bit of difference between them...
if they are restricted then you can go about lifting the throttle bodies and trying to take em off the heads...........
:thumbup cheers guys for the info and stuff....I was actually joking about the vacumn cleaner and in-situ!:laugh give me some mechanical credit!:lol ....mind you....the vacumn might still be used:devious....:puke
I'll certainly have a look soon, opening the butterflys and stuff as thats a furkin doddle.
Hell I'll even keep ya posted:)
It's Pugh, Pugh, Barney McGrew, Cuthbert, Dibble and Grubb (or crunch in this case). Pay attention to Trumpton next time!!!
you're both off ya head:eek :cuckoo :coocoo :cuckoo ...I'll walk away slowly now....
:baaa
Burn it off with a torch. :dunno
I was just going to clip off that pesky black/brown wire and thought I'd have a look in the Haynes manual. According the wire diagram, it completes the circuit of the Intake air temp sensor, tip over sensor, other pressure sensors and ends at the Engine collant temp sensor.
This sounds bad, anyone?:confused
I was just going to clip off that pesky black/brown wire and thought I'd have a look in the Haynes manual. According to the wire diagram, it completes the circuit of the Intake air temp sensor, tip over sensor, other pressure sensors and ends at the Engine collant temp sensor.
try sending your payment to the TLzone
cheers steve and dar:hail
yeah it ain't the zorsts, straight thru scorpions. must be the inlet manifolds, I'll have a look later.
:cheers guys, just paypalled my thanks to the Planet:banana
:lol
21 - 34 of 34 Posts
