1 - 20 of 22 Posts
I'm getting one, next friday it should be mine. It's race prepped with full fairings, wave rotarts, carbon exhaust, vortex rearsets and a few other bits and pieces. The suspension is stock though :banghead and I want to change it up. Whats available for the rear? I've heard you can use a stock gixxer 750 rear and it's much better than stock. Also, what all is involved with installing a complete gixxer front end on this bike? I've hear that a lot of people do these mods when racing these bikes I just havent found a lot of info on them yet. I'm getting an awesome deal on the bike, I'm getting the bike, teknik one piece leathers, two helmets, two back protectors, sidi boots, front and rear stands and a few spare parts for 2 grand :devious All I need now is a new set of tires for it and I want a set of tire warmers before the season starts again.
Now you have two you can loan me one:devious
TLS front forks bolt up upgrade the stock TLS front fork suspension and you are set. Ohlins for the rear I hear.
I put a Penske on ours, and a complete TLS front end tops it off nicely!
For the rear I've read that a stock gixxer 750 shock is good enough and fairly cheap. I didnt know any tl parts would bolt up which brings me to my next question, whos got a set of tls forks with tripple trees that they want to get rid of?
Hmmm...you *could* also use suzuki triples with Yamaha forks, brakes and wheels. :devious
Would that really be any different that using gixxer parts?
What you talking about man? :lol :lol :lol
get a 03-04 636 shock if you want a cheap adj. shock
you need a custom head bearing to bolt on a gix front end
Discussion Starter #12
So, is that your's or just a pic you found?
uhh
look at his sig line:coocoo AFM #715
umm...i found the pic somewhere on my computer ;)
T
Guest
So what did yo have to do in order to fit the Yamaha front end on your SV?
it's only yamaha calipers. they bolt right into gixxer front ends w/ special spacers
upper/lower sharkskinz made specifically for the SV, based off the original TLR design (no ducts, little slimmer), tail based from the SV
1 - 20 of 22 Posts
