need some help timing a tl motor in,
I need the sequence. front pot at TDC, and cams on firing stroke, flywheel timing mark set, and how do I time rear cylinder.
Any help pointed int he right direction greatly appreciated.
Remove the two access plugs on the generator cover, turn the crank so that the FT mark is aligned in the sight hole.
The Lines & white paint on the idler gears should be lined up pretty much spot on with the lines on the heads. If they are around 1/2 a tooth out there is a procedure in the manual to rectify it.
Fit the front cams as per the diagram below with the lines level with the gasket face.
Then turn the crank 360 Deg so the the FT mark lines up again and fit the rear cams taking note of the timing lines again.
Then turn the engine another 360 Deg back to where you started and the cams should look like the diagram below
Cheers for your help
Buzz
Related Threads
TLZone Forums
1.3M posts
31.8K members
Since 2003
