August '13 TLotM Nominations!
Results 1 to 6 of 6
Like Tree15Likes
  • 2 Post By thumpthump
  • 2 Post By Wils
  • 4 Post By J-Bone
  • 7 Post By tls ged
Thread: August '13 TLotM Nominations!
    Melbourne, Australia.
    29,854
    Here are the Rules:
    Please read them..
    -The contest is open to the TLR or TLS ONLY
    -You MUST be a MEMBER to win
    -One nomination by any MEMBER makes you eligible to win (nominations do not need to be seconded).
    -You may only nominate one other member per month
    -You MUST have at least 100 posts to be nominated
    -You CANNOT nominate yourself
    -You (or your bike) can only win once a in a 12-month period
    -Nominations will be accepted from about the 1st to the 7th of each month
    -Voting will be held from about the 8th to the 15th of each month and the poll will be open for 7 days
    Remember, only one nomination is required, so if the member you wish to nominate is already listed please don't clutter up the thread with multiple nominations for the same person/bike.
    DUPLICATE NOMINATIONS AND OTHER NON-NOMINATION POSTS WILL BE DELETED!!!!!!
    Good luck everyone!
    NOTE: When you make a nomination, PLEASE post a picture or a link to a picture of the bike you’re nominating. Don't leave it for someone else to. Thanks!!!
    AMA Pit Boss thumpthump's Avatar
    Canada
    2,047
    Toddy
    cham and hooti like this.
    98 TLS - 98 TLR
    TLotM January 2011
    TLotM May 2012
    TLotY 2012
    Superbike Twin Wils's Avatar
    Mar 2013
    Sunderland England
    191
    Patman
    cham and thumpthump like this.
    AMA Pit Boss J-Bone's Avatar
    STHLM, Sweden
    2,401
    Jollyjoiner
    hooti, jollyjoiner, Troy and 1 others like this.
    Done:
    -==- Full Akra Evo Ti w/ custom hangers -==- CZ Stage2 wheels -==- Semi-floating rotors by Speedking -==- Brembo 19x18 m/c -==- Galfer HH's -==- Galfer wavy rear -==- Bitubo shock -==- Rosmoto adj. rearsets -==- ExtremeTech damper -==- PCIII USB -==- Van's rear brake res. -==- Van's sprocket cover -==- Joe V mod -==- K&N filter -==- Galfer lines -==- 520 conv. @ 16/40 -==- Speedohealer -==- No-cut sliders -==- GSXR K2 rear caliper -==- Pairvalve mod -==- GiPro w/ ATRE -==- BRG 1/5 throttle -==- Avia Comp. C/F mirrors -==- C/F fender -==- Pyramid C/F hugger -==- GCC C/F tankprotector -==- FSMD undertail -==- LP speedscreen -==- Flush signals -==- Subframe mod. -==- GAP mod. -==- Quick release tank & seat -==- Preload adjusters -==-
    To come:
    -==- GSXR750K4 forks -==- R1 radial calipers -==- Woodcraft Clip-on's -==- Pro-Grips -==- Van's CCC -==- Van's PP -==- Van's +1mm eccentrics -==- Barnett clutch springs -==- TWM gas cap -==-
    GP Champ tls ged's Avatar
    Nov 2008
    On my TLS !
    1,271
    madmat87
    MY BIKE: 1998 TLS 107.52 Hp and 71 lb-ft.
    MODS: Yoshimura rs3, Akrapovic headers(not mounted yet), K&N air filter, power commander 2, custom sprocket cover,
    custom top triple clamp, shorty levers, clear taillight, undertray, indicators, brake lines, "fabbri" windscreen, 17/40 sprockets, fan switch mod, TRE, Ohlins rear shock, gsxr750 k5 forks, gsxr fender, r1 calipers, custom clutch actuator cap, frame sliders, axle sliders, sv belly pan, eazi-grip tank grips, 916 style mount Sprint damper, Maxton spring, modded airbox, fuel filter mod, PVM 5Y, exhaust sliders.
    SOMEDAY: adjustable rearsets, quick shifter.
    https://www.tlzone.net/forums/bike-pi...ridouts-7.html
    29,854
    Nominations closed
