2013 Hillclimb - TL doesn't have a chance
Results 1 to 3 of 3
Thread: 2013 Hillclimb - TL doesn't have a chance
    AMA Pit Boss TLJimmy's Avatar
    Jun 2008
    Masterton New Zealand
    2,684
    I stil have the fastest time for a TL - beat my P/B by 3 seconds this year; but look at the winner - cracking 300kph through the middle section! TL Jimmy is at least 70kph down on this. Need a big bore kit.
    Unfortunately there was a fatality last year, so we got a lot more runs in as less people signed up. RIP Malcolm Foster, Ducati 999.
    I did have a good battle with a RSV1000 who's rider competes at the IOM classic, but the bugger beat me by 0.02 of a second
    Here's a vid of the winning bike - I didn't have a camera this year. And yes, the speedo is correct!!
    http://www.youtube.com/watch?v=KubGVzd64rg
    BTW right at the end of the vid you can see me standing next to the tail of my TLS, in the black n white leathers holding my helmet.
    Ride it like you stole it.
    TLS CF cans;homemade SATRE;Airbox mod;K&N airfilter;'97 temp sensor mod;Iridium plugs;SV1000Coils;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors;OEM mirror mounts blanked;bar-end mirror;short rear fender with homemade numberplate/indicator bracket;damper mount mod;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini indicators;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks up 5mm with Race Tech internals - 1kg/mm springs, custom shimstack,re-valve, piston and cartridge kit;braided front brake line;billet sprocket cover;charging mod;plus mod;clutch-switch relay by-pass;stainless xhaust studs/brass nuts;welded clutch...
    TLR 'Fighter: https://www.tlzone.net/forums/suzuki-...r-build-2.html
    Evil Twin Dougie's Avatar
    Oct 2012
    Yorkshire, UK
    349
    Wow.
    Evil Twin pedrodetski's Avatar
    Sep 2011
    Holland, Alphen
    412
    Dang, that's fast! It actually changed my view on hillclimbing. I thought it mostly consisted out of shorter an steeper tracks.....
    Very cool!
    ''We don't stop riding because we grow old, we grow old because we stop riding!!''
    Pedro's Speedshop
