embed test - Page 2
Results 11 to 15 of 15
Thread: embed test
    Melbourne, Australia.
    29,854
    Quote Originally Posted by The Ring-In View Post
    If you quote yourself, you'll see the code goes {img} {url} address {/url} {/img} I don't know how or why the {url} code is getting there. Are you posting it as a link using the "link" button and then manually adding the img code?
    aaaaaaaaaarrrrrrrgggggggggjhhhhhhhhhhh!
  5. #14
    AMA Pit Boss ITSMESTEVE's Avatar
    Oct 2007
    Brisbane,AUSTRALIA
    4,456
    Lower case
    When I typed it in it didn't work
    When I copy and pasted the URL it did ?
    Red 98 TLR but looks like a yellow 02.Full Yoshi system ,airbox mod,Penske rear,SS brake lines,SteveTLS TRE,TLRstacker Sliders,Rifleman 1/5 throttle,TheRingIn swingarm pivots ,Pipercross filter,Pazzo levers,Vandriver tailrisers,Motty AFR Tuner,Projector headlights,GSXR forks,TheRingIn 30mm triple clamp offset, R1 Wheels ,brakes and swingarm,Ohlins steering damper...and counting. .......... PICK THE POINT IN THE SIG WHERE I JOINED TLZ
    Insert lame S vs R wisecrack here...
    "I refuse to prove that I exist," says God, "for proof denies faith, and without faith, I am nothing."
    Douglas Adams
    TLOTM Sept 2011........ BBOTM Nov 2011
  6. #15
    Oct 2007
    Brisbane,AUSTRALIA
    4,456
    Upper case ?
    Douglas Adams
