Not your usual exhaust bolt thread - Page 2
Results 11 to 20 of 20
Thread: Not your usual exhaust bolt thread
    Silver Subscriber cyclecamper's Avatar
    Jan 2005
    Chicago, Long Beach CA now Virginia
    7,697
    Quote Originally Posted by Kamikuza View Post
    ... just realized I can't use studs - stupid Yosh uses springs
    I don't understand. What do the Yosh springs anchor to? Don't you still need bolts? Can't you use a stud and nut anyplace you use a bolt? Please explain because I too have a Yosh full system but I have no clue how it instalss.
    MotoGP Pit Boss Kamikuza's Avatar
    Mar 2005
    Shiga, Japan
    11,918
    The nuts have a 2.5mm diameter hole drilled side-to-side through them that the spring slips through - otherwise, they are the same as the OEM bolts ... You could just drill a hole through the stud but there's no way to be sure which way it'd end up facing ...
    Today's Update
    I came inside covered in muck and the wife asked what I'd been doing.
    When I replied that I had, in fact, been working on the bike she responded "Really? But I couldn't hear you swearing." so things are still going well!
    Bought some new exhaust bolts - M8x25 from the DIO store, drilled the holes myself (see above) and only buggered one up and my 2mm drill bit - dunno why - but I got a pack of 5 bolts so I got 2 perfect ones out of the 3 I attempted
    SOAKED the bolts in Loctite anti-sieze, slotted it all back together ... test fitted the sensor - almost bloody perfect position!
    Started the bike - no leaks!
    Now I just gotta wire it all in!
    WSB Pit boss Octofinger's Avatar
    Mar 2005
    Mid Sweden
    6,760
    You bought SS bolts?
    Done: -98 thermostat housing + bypass mod, Rifleman's 1/5'th, black screen, 17/40 sprockets, home made ATRE, Bitubo rear shock, Barnett clutch springs, split steering damper bracket, iridium plugs, D&D CF full system, +/- mod, Van fork sliders, Ziggy999 frame sliders, Pazzo shorty levers, US headlight, Busa front MC, Galfer SS lines, TLR 6-potters, airbox mod, PCII, Van sprocket cover, EBC front brake discs, TI rotor bolts, Van clear clutch cover, 6-spring clutch, Van clutch plate, Scotts oil filter, K&N, Stealth sprocket, full TLR M4 system, custom oil cooler bracket, Geelong CF tank bra.
    Todo:CF undertail/gap mod, Discacciati discs, fork revalving, improve crank case breather, custom head light
  5. #14
    Sam is offline
    Oct 2010
    Milton Keynes in England
    15,403
    Quote Originally Posted by cyclecamper View Post
    You can still use studs, just make 2 egg shaped washers and drill the spring holes in them
    TLOTM Nov 04, March 06, June 07, July 10, Aug 11, Sept 12 and TLOTY 2007 and 2010
    PM Me for Help & Prices with GSXR/Busa Radial Fork Conversion Kits and Welded Clutch Centres
  6. #15
    Mar 2005
    Mid Sweden
    6,760
  7. #16
    Mar 2005
    Shiga, Japan
    11,918
    Quote Originally Posted by Octofinger View Post
    Probably ... why?
  8. #17
    Mar 2005
    Mid Sweden
    6,760
    Probably ... why?
    Because that's what have helped me I guess. They have much less probability to get stuck.
    Iron and aluminium is not a good combo.
  9. #18
    Sam is offline
    Oct 2010
    15,403
    Octo
    I use stainless bolts aswell with a liberal coating of copper slip, but to be honest once you have got the stock bolts out it's very rare for replacements to seize unless they were fitted dry again and done another 20k miles all year round.
  10. #19
    Mar 2005
    Shiga, Japan
    11,918
    Which is what I did with the Yosh bolts I just replaced Sam however, there's so much Loctite Silver in there now it smokes when it warms up
  11. #20
    AMA Pit Boss cikko's Avatar
    Jan 2005
    Aylesbury/UK
    3,673
    Great thread Kami...
    You actually made me laugh.
    1) for being so jinxy as to dare mention ANYTHING is going well.
    2) for wife no hearing your swearing
    It appears that I apparently don't enjoy anything anymore... I sweat and curse while doing jobs in garage, car &/or house and I'm a nightmare to live with "apparently" - being a right old grumpy barsteward.
    So it is with GREAT delight that you are enjoying yoruself and it brought a smile to my face ... oohhh eerrr
    that'll be may face cracking and sliding off then.
