Best mod for a TL1000s...looks wise...
View Poll Results: Best looks improvement device
Voters
300. You may not vote on this poll
  • Lower fairings
    44 14.67%
  • Belly pan
    56 18.67%
  • Aftermarket screen
    48 16.00%
  • Single seat conversion
    29 9.67%
  • Carbon mudguard
    20 6.67%
  • Rearsets
    31 10.33%
  • Aftermarket cans
    106 35.33%
  • High level exhausts
    77 25.67%
  • Flat bars
    15 5.00%
  • Other: will explain
    52 17.33%
Multiple Choice Poll.
Page 1 of 14 1234511 ... LastLast
Results 1 to 10 of 132
Like Tree15Likes
Thread: Best mod for a TL1000s...looks wise...
    Sep 2005
    Scotland
    262
    Not talking about suspension or the like....but what can you add change to the tl1000s to make it look better?
    Multiple choices within the poll as I'm assuming aftermarket cans are a given
    Mar 2003
    Dalton, Ohio
    8,216
    I'm going to go with - trade it for an R.
    JoshCampbell likes this.
    Jan 2007
    551
    Quote Originally Posted by 1crock View Post
    agreed but out of all of them it would be a steering dampener.
    WSB Pit boss daveC's Avatar
    Jul 2004
    At home...probably.
    7,318
    I would say a high level exhaust.
    One Liter Duc Eater Pfunk's Avatar
    Jan 2004
    793
    A nice set of light 10-spoke wheels. Look great and make it handle better.
    Aug 2006
    Knoxville, TN
    722
    I think the single best appearance mod is installing the rear seat cowl, the factory one that is pointy and kinda tall. Really makes the tail look better in my opinion, the passenger pillion is ugly, flat in an area that shouldn't be.
    Mar 2003
    Dalton, Ohio
    8,216
    Quote Originally Posted by xbubbax View Post
    Ahem! A dampener just makes things wet, how would that improve the looks of an S?
    SWAMPTROLL likes this.
    AMA Pit Boss billy_tlr's Avatar
    Aug 2005
    Newton le Willows UK
    2,569
    from the list id say high level pipes but ya just cant beat new wheels look great and make it ride better
    mods up to now:- M4 headers quill links/GP1's,OZ hl02 magnesium wheels pipercross filter, Tre, powder coated frame/mirror brace, gilles rearsets, wavy rotors, superchips ecu, gilles variobars, front axel sliders, harris rear and 06 R1 front calipers, gap mod, billet rear brake res f&r, ohlins rear, pazzoracing levers, vans sprocket cover, gilles chain adjusters, braided SS hoses, cable clutch, double bubble, billet oil filler cap,1/5 throttle insert, datatool digigear, carbon fibre ram air covers, wavey rear disc, soft limiter wire cut, yoshimura bar ends, billet swingarm pivot caps, harris billet gas cap, 43 tooth rear sprocket, vans tail risers, Kad tripple, ilumiglo gauges, +/- mod, Ohlins steering damper,busa forks with radial bottoms,30shot dry NOS, carbon k3/4 fender pit-eck undertray, billet clear clutch cover,
    TLOTM April 06 + May 07 + June 09
    Superbike Twin skippermccoy's Avatar
    Mar 2005
    manchester tn
    162
    Gap tray and tail riser with the solo cowl. I have lowers for mine but hell its an S and the open motor is a big part of what sets it apart from the rest. I had the lowers mounted for maybe 3 days and had to take them off. I think it took longer to make mounts for them then they were on the bike
    One Liter Duc Eater moun10's Avatar
    Jun 2005
    IL
    945
    I went with other because I think cleaning up the back end with a undertail makes a big difference looks-wise.
    2001 TL1000S Blue | Rifleman's 1/5 throttle insert | JSD-3A TRE | Zero Gravity Double Bubble | Topgun Undertail | Clear Alternatives Flasher Module | ET79's Fan Switch | K&N Air Filter | PCIII | Yoshimura RS-3 Bolt-Ons
best rearsets for tl1000s
duke 690 clear clutch cover
tl 1000s tailpiece mod
tl1000 images
tl1000s bar mod
tl1000s brake mod
tl1000s coolest
tl1000s gap mod
tl1000s undertail
tl1000s windscreen bar mod
uki tl 1000 r resistor mod
what does a tls 1000 suzuki look like
