1997 TL1000S over feuling issue - Page 4
Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: 1997 TL1000S over feuling issue
  1. #31
    WSB Pit boss tlsgazza's Avatar
    May 2004
    wellingborough, northants, UK
    5,650
    Quote Originally Posted by V enjin#1000 View Post
    The fast idle lever has no effect, i changed the cable when i bought it cause the original 1 broke. About the thermostat its an 82'C i couldnt find a higher one that would fit into the housing. Does the ECU go back to cold map if the temp goes below 80'C.
    I would say yes. I'm sure mine was running rich at the lower temperatures most of the time before i did the mod on mine.
    You have relocated the wiring for the temperature pick up from the radiator to the new thermostat housing I take it.
    Fast idle cable probably needs adjusting to get it to work better. You could have done that when you had it apart to change the thermostat housing. :Baghdad
    black TL1000Sx, owned from new, 01/08/1998, 86.000 miles.
    Red TL1000sv ,original 97 , bought from my girlfriend when we split owned by us since 2004. 30.000 miles.
    Honda XL500r. 1983. Owned since 1997. 30.000kms.
    r1200gs adventure with 106.000 miles.
  2. #32
    Mar 2013
    South East Wales
    2,688
    Quote Originally Posted by tlsgazza View Post
    :Baghdad
  3. #33
    Baby Twin wilf's Avatar
    Aug 2014
    south london
    44
    me too
    tls 1997 1040 big bore flowed heads tony cook exhaust airbox mod undertray dyna coils r1 regulator rifleman throttle insert
    30 litre petrol tank tlr six spring clutch with welded centre full maxton suspension front
    and rear tlr swinging arm six pot front calipers goodridge brake lines alround headlight
    relay mod fim programable fuel injection gel seat temp mode switch gsxr 600 rear wheel and 180 rear profile tyre sprint steering damper 17/42 sprockets powerbronze screen tlr camshafts degreed in cams by sam ,owned from new and still under development
  5. #34
    Baby Twin V enjin#1000's Avatar
    Dec 2019
    36
    U were correct, i adjusted the fast idle screw and now it idles like it should when started. I did the thermostat mod. My TL runs alot hotter as prevously with factory thermostat. I am going to pull the injectors next week to have a look.
  6. #35
    May 2004
    5,650
    Quote Originally Posted by CrashB View Post
    Quote Originally Posted by wilf View Post
    me too
    Bloody spellcheck caught me out again. Should have been banghead. ie:. .
  7. #36
    Dec 2019
    36
    😭today my TL oil level have risen again.....thermostat i have in it now is not right,Tl runs to cool. I saw on another thread here on the forum that a DL1000 has the thermostat that i am looking for an 88°C one. Will that one fit? If i buy a whole unit will i be able to use it? Its almost winter soon here in south Africa. I just want to get my TL sorted? Any help TL lovers please
  8. #37
    Dec 2019
    36
    I have been monitoring it since i put in new oil it didnt rise? Does must have happened overnight? Faulty regulator or injector is suspect
  9. #38
    Baby Twin moskovchenko's Avatar
    Mar 2019
    Saint-Petersburg, Russia
    6
    Thermostat 88°C Tama W44DX-88, STANT 29209 buy in auto parts, or from Suzuki DL
    suzuki gsf750 97 - sold
    kawasaki er-6n 06 - sale
    izh cossack 76
    suzuki tls 97
  10. #39
    May 2004
    5,650
    I'm going to ask the obvious.
    Is the radiator staying cold until the engine gets to a certain temperature. ie: around 80°c. Then once warm when the thermostat opens the coolant should then flow throught he radiator to maintain temperature.
    It still sounds to me like either the wrong stat or its staying open.
