C41, No Relay click, no fuel pump prime. some help plz. - Page 4
Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: C41, No Relay click, no fuel pump prime. some help plz.
  1. #31
    May 2015
    20
    just an update,
    I did receive the new pump. I am going to tackle this over the weekend. I will update after the weekend.
    thank you all again.
  2. #32
    May 2015
    20
    ok!!!
    after some fun weekend work I finally got the new fuel pump in. After reassembling the pump I tried plugging in the pump directly to 12v......the pump works
    then I tried plugging the fuel pump system to the relay / wiring harness and seeing if I got anything. turned the key and no relay clicks and no sound from the pump.
    I am still not getting a drop across yellow / blue.
    When i probe this wire and turn the key to the on position i do not get a 3 sec voltage drop to signal the relay. I guessing i blew the resistor in the computer is now its fried.
    I am suspecting when I was trying to diagnose this on my own I may have jumped the Yel / Blue to direct power, frying the resistor in the computer.
    thank you again for all your help
    I have a feeling were almost there.
  3. #33
    Baby Twin tsjoe007's Avatar
    Apr 2015
    Belgium
    18
    Ok so far so good, as I already said I experienced the same problem(s) only I solved them vice versa, first the ECU swap, then the fuel pump swap and the start relay fix.
    I hope the ECU swap brings back the sleeping beast !
  5. #34
    May 2015
    20
    thank you tsjoe007
    im looking for a computer now.
    if anyone has an extra one that is fora TLR I would buy it
  6. #35
    Apr 2015
    Belgium
    18
    Where are you located ?
  7. #36
    May 2015
    20
    Massachusetts USA
  8. #37
    Apr 2015
    Belgium
    18
    Then I’m afraid I can’t help you as de European ECU’s are # from the US models.
