97 tl1000s looking for help
Results 1 to 6 of 6
Thread: 97 tl1000s looking for help
    Aug 2019
    5
    i was recently given my best friends 97 tl1000s.... sadly he passed away two years ago.. this bike was his baby but is also a huge pain the butt.... he has a ton of trick parts on it, pc3 etc... after sitting for 2 years the bike was drained and filled fresh.. the bike will start up run for abouit 10-12 seconds and then its like someonwe shuts it off... you can start it back up maybe 1-2 times but after that, it just cranks over and you have to let it sit for alittlew while before shell start again... as long as you stay on the throttle she will run let off she quits.... any help??
    Mar 2013
    South East Wales
    2,686
    Check idle, fast idle and TPS then report back.
    Aug 2019
    5
    idleing is right about 1400.... how do i switch the mode selector so i can check the tps location on the gauge screen
    Jul 2019
    Portishead..Somerset UK
    22
    You will have to check the TPS by accessing the dealer plug thatís in the rear of the bike either under the seat or in the rear seat pod. Plenty of info on the net and on here . Once you have accessed it you use the dash to see whatís what. Have a look and itíll make more sense
    Aug 2019
    5
    question is how do i access the dealer plug to reveal the tps read out on the dash
    Aug 2019
    5
    UPDATE!!! the tps read out is in the middle... the bike will run at idle above 1600-1700...... is you back the idle screw out to the norm of 12-1400 i hear a sort of hiss sounding like air escaping from under the tank, itll do this a couple times then stalls out...... ? ideas....
