TL Fan mod idea - Hook up to rear brake - Page 2
Results 11 to 12 of 12
Thread: TL Fan mod idea - Hook up to rear brake
    Jul 2019
    6
    I have the manual switch, still too hot. I got water wetter to see how that will do.
    WSB Pit boss tlsgazza's Avatar
    May 2004
    wellingborough, northants, UK
    5,636
    Quote Originally Posted by Hollywoodmx View Post
    So you have a manual switch, which in my opinion would be simpler to use than a brake pedal mounted switch which you only use when stopped or are infact braking, but it is still too hot.
    Just fit a 95`c fan switch and be done with it. Couldn't be easier. It will always turn the fan on before the engine gets too hot.
    Both my TLs's have one fitted. Couldn't be easier.
    black TL1000S rider,owned from new since august 98,hinkle windowed clutch cover,braided lines,5/8 front brake M/cylinder.1/5 throttle,Helibars,double bubble,stainless renegade cans, ohlins damper,stainless rad and oil cooler covers,undertray,carbon hugger,silver powdercoated wheels,k+n filter and TRE,R+G bungs,LED indicators,gold X ring chain with 40T rear sprocket,mini indicators, HID H4 headlights with led side lights.now done 85,000 miles.
    gold busa forks,gold six pots and gold rear caliper,pazzo levers all thanks to speedking
    van driver clutch pressure plate and bolt retainers,
    also done 306 laps of the nurburgring,
    now have my r1200gs adventure with 95.000 miles covered to date.
