1000r no power to ignition
Results 1 to 4 of 4
Thread: 1000r no power to ignition
    May 2018
    1
    If anybody's bike cuts out when running it's just took me 2 hours to find out why but check the wires from ignition barrel under the tank they sit on top of the radiator and mine were snapped so if anybody has same problem check here first hope this helps john
    4,037
    Odd failure. The loom from the ignition switch on my TLR is not even near the radiator.
    Still, thanks for the heads up, and welcome to the Zone Johnboy!
    Aug 2014
    San Antonio, Texas
    1,753
    Quote Originally Posted by Johnboytlr View Post
    ... the wires from ignition barrel under the tank they sit on top of the radiator and mine were snapped ...
    Well that's a new one
    The ignition Cylinder wire should be covered by a durable sheath and routed through a metal ring just below the triple. From there it gets routed between the forks and attaches to a small loom clip benieth the tank along the left side of the frame.
    Maybe I'm wrong here though. I can't seem to find any decent images in my stash.
    Aug 2014
    San Antonio, Texas
    1,753
    Ok, I see what the OP is saying now. The green plug at the front of the frame is the ignition wire. It does, in fact, route between the forks, above the radiator, and sits under the tank. Still have no clue as to what could sever them though. Unless he's missing that protective plastic shroud.
    Attached Thumbnails Attached Thumbnails 1000r no power to ignition-img_0064_1527654236572.jpg   1000r no power to ignition-img_1901_1527654671802.jpg
