Problems with tl1000s engine
Results 1 to 4 of 4
Thread: Problems with tl1000s engine
    May 2018
    1
    UnhappyProblems with tl1000s engine
    Hi mates! I've got a problems with a 1997 suzuki tl1000s. One of cylinders stopped working after short ride. Firstly, I thought that it might be plug problems but after changing plugs problem remained the same... There is something strange high knocking sound when engine warmed. Also exhaust pipes of both cylinders are warm. Today I measured compression - so front cylinder compression is 850, second is 800. Both cylinders are working but bike does not 'pull' like it should. Current engine thrust is about 20-30% from main. Where might be a problem? Someone faced with a similar problem? Thanks for reading!
    P.S. I owned that bike less month. I rode around 300-400 km...
    Did you fit NEW plugs?
    Mar 2003
    Dalton, Ohio
    8,213
    Howdy, welcome and what Stu said.
    Baby Twin TOOKA's Avatar
    Jan 2013
    5
    Hello darktree. Sounds like the plug lead is breaking down when she warms up. Wouldn't heart to try a new lead. If its the rear cylinder which l wouldn't be surprised it tends to get a little hotter causing hardening of the lead over many years. Give it a go..you never know.
