97 v 98 tls question? - Page 2
Results 11 to 13 of 13
Thread: 97 v 98 tls question?
    the 97 became a 98 in october
    10/97 is a 98
    Dec 2019
    Will the 1998 full oem exhaust system mount right up to the 1997 TL1000S?
    WSB Pit boss tlsgazza's Avatar
    May 2004
    wellingborough, northants, UK
    5,624
    Quote Originally Posted by zack.hipskin View Post
    Yep the same. The later were fitted with a better output shaft and bearing on the gearbox as well afaik
    black TL1000S rider,owned from new since august 98,hinkle windowed clutch cover,braided lines,5/8 front brake M/cylinder.1/5 throttle,Helibars,double bubble,stainless renegade cans, ohlins damper,stainless rad and oil cooler covers,undertray,carbon hugger,silver powdercoated wheels,k+n filter and TRE,R+G bungs,LED indicators,gold X ring chain with 40T rear sprocket,mini indicators, HID H4 headlights with led side lights.now done 85,000 miles.
    gold busa forks,gold six pots and gold rear caliper,pazzo levers all thanks to speedking
    van driver clutch pressure plate and bolt retainers,
    also done 306 laps of the nurburgring,
    now have my r1200gs adventure with 95.000 miles covered to date.
