The S died so I got a new bike!
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By The Ring-In
Thread: The S died so I got a new bike!
    AMA Pit Boss TLJimmy's Avatar
    Jun 2008
    Masterton New Zealand
    2,684
    THREE guesses!
    Ride it like you stole it.
    TLS CF cans;homemade SATRE;Airbox mod;K&N airfilter;'97 temp sensor mod;Iridium plugs;SV1000Coils;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors;OEM mirror mounts blanked;bar-end mirror;short rear fender with homemade numberplate/indicator bracket;damper mount mod;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini indicators;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks up 5mm with Race Tech internals - 1kg/mm springs, custom shimstack,re-valve, piston and cartridge kit;braided front brake line;billet sprocket cover;charging mod;plus mod;clutch-switch relay by-pass;stainless xhaust studs/brass nuts;welded clutch...
    TLR 'Fighter: https://www.tlzone.net/forums/suzuki-...r-build-2.html
    AMA Pit Boss Moyston's Avatar
    Oct 2007
    Melbourne , Great OZ
    3,297
    an R
    Stop staring at my Tits!!
    An S
    An S
    An S
    cham likes this.
    Jun 2008
    2,684
    speed triple
    Oct 2007
    3,297
    AMA Pit Boss Big Red's Avatar
    Sep 2006
    Ipswich,Aus
    2,920
    You will love it Jimmy , I wish I could have had mine over there . What year ?
    The bike that is .
    1050 Speed Triple
    Wilbers rear shock ,Racetech Gold valves + Wilbers springs in the front end ,MIVV pipe ,Triumph bar end mirrors ,Triumph hugger ,Tidy tail ,FP Racing levers ,D'Ecosse Rec/Reg mod ,Crazymofo rad guard ,Oggy knobbs ,Triumph bug screen ,Ventura headlight protectors ,Upgraded alternator + more to come .
    The bike that was .
    TLS
    FP levers ,Leo Vince cans ,Bitubo ,Suspension Tech valves ,Eibach springs ,Ohlins steering damper ,Barnett clutch springs ,K&N air filter ,flapper valve and associated shite removed ,Irridium plugs ,PC11 ,Loweys TRE ,Charging mod ,Jarkkos plus mod , DavCruz fan switch mod ,Six pots ,Braided lines ,Riflemans ccc ,The Ring Ins modded pressure plate ,dropped one tooth on the front sprocket ,Van drivers sprocket cover + front and rear resovoirs ,TLR engine breather/separator .
    another member of the 2+1 club!
    fatty likes this.
    4,047
    Jimmy, I can relate to the attraction.......
    Do you intend to fix your TL?
    d'ecosse can be found on the triumph rat forum.
    he'll recognise you when you join..............
