Dead bike...electrical?
Results 1 to 10 of 10
Thread: Dead bike...electrical?
    GP Champ AU.TLS's Avatar
    Sep 2003
    Brisneyland, Australia
    1,209
    Recently had problems with the plug on the starter relay melting so replaced that and all was fine. But the other day I went out for a ride and stopped for a break then went to start the bike and I'm not getting any lights or display when I turn the key. Similar symptoms to when the plug melted except no amount of jiggling of the plug or bending the pins could get it to come alive again. Checked all the plugs up near the ignition and they're all still clean with no corrosion. Battery shop load tested the battery and it was fine.
    I've tested the top two pins on the starter relay and i'm getting 12.5V but I read on here that testing across the bottom pins you should see a reading of 3-6ohms which I'm not. Does that indicate that my starter relay is dead? Not sure what else to check now or if I should just buy a new starter relay to test?
    4,047
    Have you checked the Main Fuse? (edit: After thinking about it. You said the are 12 volts at the two top pins, so main fuse should be good. )
    Even if the coil in the relay were open (no measurable resistance), you should still have lights and such when you key on.
    Often when the starter relay connector overheats, the relay itself deforms and burns as well as the loom connector. It is best to replace both parts when they have encountered serious heat.
    The lights, ignition, and even the starter button power all come through that RED wire coming from the starter relay connector.
    Also verify the battery cable connections. They vibrate loose.
    One more thing. Check the main loom ground wire. It is a Blk/Wht wire (14 gage) that runs parallel to the negative battery cable. It has a spade connector that tends to corrode.
    Dec 2012
    Bucks, UK
    3,454
    Was the replacement relay OEM? I've had problems with the aftermarket ones. They just don't seem to handle the loads very well.
    AMA Pit Boss Moyston's Avatar
    Oct 2007
    Melbourne , Great OZ
    3,298
    I wouldn't go buying anything until I check all the known faults for causing it , but dont focus just on the relay as the main prob, cld be a coincidence.....you prob have already , that earth cable from the relay that connects to the side of the engine, just above the front sprocket...as six says..thats were the little spade is and can corrode....
    Stop staring at my Tits!!
    Aug 2014
    San Antonio, Texas
    1,759
    I just had the exact same issue not two weeks ago. Swapped out the old 4-wire connector with a new one and all is well
    Give this thread a quick read-over. Six5 threw out an excellent piece on the relay.
    if you can't sort it then PM me
    I'm in brisbane too...
    Sep 2003
    1,209
    So went over all the grounds and plugs again and couldn't find any corrosion or issues. I just received a new lithium battery for my DR650 and decided to chuck it in the TL and try it and what do you know turned the key and all was good.
    Took the TL battery to a different battery shop this time to get tested again and this place said it's dropped a cell. So bought a new battery and seems to be all good now. Still don't 100% trust the bike at the moment because that's the second time i've been left stuck on the side of the road. Might just do some short rides for a while to make sure all the electrical gremlins are gone.
    Thanks for the help guys.
    4,047
    Quote Originally Posted by AU.TLS View Post
    ..... So bought a new battery and seems to be all good now. Still don't 100% trust the bike at the moment because that's the second time i've been left stuck on the side of the road. Might just do some short rides for a while to make sure all the electrical gremlins are gone.
    Glad you are back on the road again.
    However, until you address and fix the underlying problems that cause the starter relay connector to fail, you will continue to have battery charging problems and low system voltages. Don't stray too far from home.
    Sep 2003
    1,209
    When the plug melted the first time I replaced the connector with a new one and at the same time I did the R/R mod using a wiring kit from Eastern Beaver and a yamaha r1 regulator because I was having issues with the lights dimming when I revved the engine. I now get 13.7v at the terminals when the bike is idling.
    What else should I be looking at to ensure the bike is more reliable?
    4,047
    .... I did the R/R mod using a wiring kit from Eastern Beaver and a yamaha r1 regulator because I was having issues with the lights dimming when I revved the engine. ....
    That's good. The installation of the Charging Mod gets you half way there. Now you need to remove the headlight current from going through the starter relay connector. That is the bulk of the current in the system and it over heats that little terminal on the solid RED wire. The most common fix is the Headlight Relay Mod. It provides a separate, heavy duty path for the headlight current, and makes the system very reliable.
    Be sure to use quality fuse holders or fuse blocks in the Charging Mod and H-R Mod. I have had both systems fail due to less than 'quality' fuse holders. The fuse holder in the Headlight Relay circuit on my TLS overheated recently and opened the circuit. It lasted five years, but better components could make it nearly bulletproof.
    The details for the H-R Mod can be found here.
    https://www.tlzone.net/forums/frequen...ki-wiring.html
