lights on dials dulling why? - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: lights on dials dulling why?
  1. #21
    Dec 2012
    Bucks, UK
    3,454
    I was also thinking about 6V lamps being installed but it would be a little unusual unless maddi has bought a job lot and keeps putting them in when they pop.
    6V bulbs aren't that common here outside of specialist auto shops so they are not something you just pick up at your local filling station.
    I'm assuming those readings were taken across the battery rather than in one of the brake lamp sockets otherwise they should be 0V before the pedal is pressed and 12ish afterwards.
  2. #22
    Dec 2012
    Bucks, UK
    3,454
    And since the brake/tail light bulbs are combined if it was 6V bulbs in there the tail lamps would be popping too.
  3. #23
    4,047
    Quote Originally Posted by snowblind View Post
    I was also thinking about 6V lamps being installed but .....
    6V bulbs aren't that common here outside of specialist auto shops ....
    I agree on the brake light voltage behavior.
    However, if the readings were taken across the battery, as you suspect, then seeing 10.6V after the activation of the brake light is bad news.
    Yep.
    We just need more detailed descriptions from the OP concerning his methods and measurements.
  5. #24
    Mar 2015
    Ireland
    78
    Yes they were new bulbs. Just checked the packet.........6 volt bulbs I picked them up in the motorbike section of Halford never looked at them just presumed they would be right!
    All voltage reading I talked about were read from the bulb housing not the battery
  6. #25
    4,047
    Quote Originally Posted by maddi680 View Post
    Yes they were new bulbs. Just checked the packet.........6 volt bulbs ....
    That's why the running light filament was REALLY BRIGHT. It was on the verge of frying!
    Now you know for next time.
    You still need to fix your charging system.
  7. #26
    Dec 2012
    Bucks, UK
    3,454
    So it was the "simple" solution in the end. Still surprising. I haven't seen a bike with 6V electrics for years and I've never noticed 6V bulbs in Halfords.
  8. #27
    Mar 2015
    Ireland
    78
    I know that's why I just presumed they were 12v. I'll take a picture tomorrow and show just to prove I'm not messing!
  9. #28
    GP Champ rxf610's Avatar
    Georgia, US
    1,746
    Did you accidentally grab the 6 volt
    +1 million to Six.
  10. #29
    Mar 2015
    Ireland
    78
    Thanks for the help boys. I'm new to the tl game
