Air scoops
Results 1 to 3 of 3
Thread: Air scoops
    Sep 2015
    Nova Scotia, Canada
    122
    Air scoops
    I removed the fairing on my TLs for some maintenance and
    noticed that the intakes scoop seems to float. No screws are missing
    but it does move back and forth on the centre screw.
    Is this normal or should it mount firm to the side of the fairing?
    Canadian FJR
    4,047
    The side play is normal. It allows for a less than perfect alignment between the airbox location and the multiple fairing mounting points. If all the parts were rigidly bolted together, you can be sure there would be alignment issues - on some bikes more than others.
    Sep 2015
    Nova Scotia, Canada
    122
    Perfect, thanks for the reply.
    Canadian FJR
