no power to gauge cluster but motor runs
Results 1 to 10 of 10
Thread: no power to gauge cluster but motor runs
    Dec 2015
    13
    Everything worked fine a couple minutes later no gauge.
    Fuel pump works
    Ecu turns on engine runs
    Please help
    4,047
    The engine will run without the instrument cluster connected. That's normal.
    You have lost power to the instruments for some reason. Do the horn and brake lights work OK?
    Check the Signal fuse, #4. If it is OK, check continuity from the Signal fuse to the Orange/Green wire on the instrument connector.
    Dec 2015
    13
    First off thank u for helping me.
    I don't have horn head lights or break lights the motor is in a yamaha rhino also were does the power come from
    4,047
    Quote Originally Posted by tlrhuss View Post
    .... were does the power come from
    The current path for the instrument's power is as follows:
    • Battery + to the starter relay.
    • Solid Red wire in starter relay connector to ignition switch.
    • Ignition Switch ON connects Red wire to Orange wire.
    • Orange wire to Large White Gang Connector (LWGC) between the main loom and the front loom.
    • From LWGC, Black/Red wire to Fuse box - this feeds fuses #3 (Ignition) and #4 (Signal).
    • DarkGreen wire from Signal fuse is spliced within the loom to the Orange/Green wire which goes to the instrument cluster connector.
    • Also verify that the return circuit is intact. That is the Black/Wht wire in the instrument connector to chassis ground.
    Since the engine runs, you know the the power feed up to the fuse box is good. After that point (Signal fuse), it is in question. You should be able to find the open fairly easily with a meter, or test light.
    Dec 2015
    13
    Thank u sir I do appreciate it I am going to get Christmas out of the way then mess with it but honestly thank u so much I also have a post up there about exhaust system if u are in the no how with that as well much apreciated
    Dec 2015
    13
    Ok now this might be a bad question bit no question is a bad question if I don't have a good ground would I not have any power still
    4,047
    .... if I don't have a good ground would I not have any power still
    That's right. If the circuit is not complete, the instruments will not power up.
    See the wiring diagram on page 8-14 in the service manual. It will help you trace the circuit.
    Dec 2015
    13
    Well it works I don't know how but it does thank u
    4,047
    Glad to hear it.
    Feel free to post photos or a video of your modified rhino so we can see the fruits of your labors.
    Dec 2015
    13
    I will defenetly I just left to go to Texas for work IL be there for a month or so I won't have a lot of time working 12 hours a day 7 days a weak but just friend me and when I get back IL find a way to send pics and videos
